Angles on the front drive shaft check 10 degree. What is recommended angle to shoot for?
It's not so much the angle of the driveshaft we are concerned with (though ultimate that matters too) regarding changing the angle of the pinion. It's the relationship angle between the pinion shaft and the driveshaft. In other words, the working angle of the front u-joint.
If you just keep tilting the axle back at the top, eventually the u-joint will be in a bind.
At some point, the upper CV section can bind too of course, but I don't remember what that working angle is. Maybe 25 degrees?
The front u-joint max working angle is somewhat less if I remember. Maybe 15 degrees? Others will know.
Basically if it was all adjustable and we set it up however we want, the front u-joint would be working at just a slight offset from the centerline of the driveshaft. Not much, but not zero either. Just enough to keep the u-joint working and lubricated and working, but not so much it weakens it too much.
Any cardan style joint like we have, whether it's a single-cardan like at the differentials, or a double-cardan like at the transfer case, gets progressively weaker as the angle increases. After a few degrees it increases a LOT.
Which is why, when in four-wheel drive, you
NEVER get on the gas hard with your front wheels turned tight. Or at least keep it in the back of your mind as you're trying to get unstuck or over an obstacle.
Many a front joint and axle shaft have given their all under those conditions.
But for this discussion we were talking more about binding and vibration than actual failure points.
If your driveshaft is 10° down and your front pinion is 9° up (offset of 1 degree) then you can add more C-bushing no problem. Adding the full 7 would put you at 8 degrees or so. I say "or so" because the pinion is not in the centerline of the axle shafts, which is what the C-bushings are acting upon. I don't think I've ever read where anyone has actually calculated, or measured the degree change of the pinion when compared to the axle housing.
Alternately, if it's 10 down for the driveshaft and 20 down for the pinion, meaning it's another 19 extra degrees in the wrong direction, you're running up against a limit of the u-joint's ability to spin. And long before that, you'd have at least felt a vibration when in four-wheel drive.
They're just not able to work efficiently at those higher angles.
Yours looks to be pretty close to zero, but pictures lie when it comes to angles and perspective. If you can measure the angle on the pinion, then you'd know for sure. Some kind of straight-edge on the yoke, like a framing square, would do the trick.
