c4 help!
bax
Old Member
I have the valve body out of the trans. I was having some line presure issues and was looking for a stuck valve. I think I found one but now i am putting it back together and there a 3 check balls. 2 on one side of the plate and one on the other side of the plate. I know where the 2 go but have no idea where the other one goes. Anyone got a diagram ?
DEEPWOODS
c4
Bax look in bronco tech -c4 improvements there are pics that shows where the check balls go.I don't remember but 2 balls but it has been about 2 years since I went through mine
bronconut73
Maybe Bax just has extra balls. Lol.
I mean....it seems like he does here on CB. Ha.
cs_88
Pictures courtesy of Viperwolf.
bax
bax
Old Member
Thanks Guys I have it back together. Still broke. I was hoping for a stuck valve in the valve body. Never found anything wrong. put it back together. Still have a weak reverse and no high gear. So it must be a pump / line pressure issue.
tasker
all knowing of nothing
NH
so your balls are placed correctly and your pump does not work?
Viperwolf1
electron whisperer
Could still be a clutch seal issue. How did the pressure look?
bax
bax
Old Member
I got the gauges to check it but it really doesn't matter. It has to be removed to be fixed. If the pump is bad it will have bad pressure and if a seal is rolled over it will have bad pressure. F'ed either way.
Viperwolf1
electron whisperer
If the pump is bad it will have low pressure. If a direct clutch seal is bad it will have good pressure until it trys to shift into 3rd or reverse. It can point to the problem area but if you already dumped the oil no sense testing pressure. Just check everything while its apart.
I just opened up one today that had no 3rd gear but reverse worked. Pump, seals, and valve body were all fine. Direct clutch piston was cracked.
bax
bax
Old Member
oil is still in it. I put it back just to see if I some how fixed it. wish full thinking. I will pressure test it tomorrow just to see.
