c4 neutral saftey switch plug
blainebrazil
Santa Rosa
i need the plug that connects the wiring harness to the c4 neutral safety switch on the transmission. I could hard wire it, but i thought i would see if anyone has a spare laying around that they would sell me.
thanks
phred
Earth
If I remember correctly the plug is molded to the neutral safety switch harness. Im not sure but just about any vehicle with a C4 should have that plug and you could pick one up at a yard for pennies or a tranny shop my have an old one laying around you could cut then end from.
tasker
all knowing of nothing
NH
belive i have one from a plow harness, pretty sure they are the same. If they are you can have it.
Viperwolf1
electron whisperer
I have not been able to locate that particular plug for sale anywhere. An option is to use two 2-pin flat plugs in place of it. I've even JB welded the two 2-pins together to make a 4-pin.
blainebrazil
blainebrazil
Santa Rosa
i need the plug coming from the main harness that plugs into the plug on the NSS
tasker
NH
that's what i got.....just rewired my engine bay so i know i've looked at it....4 wire, two exposed and two not, right?
tasker
NH
done deal, Viper you need one too?
