70HalfCab
The gasket between the back of my C4 and the adapter housing is leaking really bad. It has been a long time since I’ve had this apart so just need a bit of guidance. If I unbolt the adapter housing from the back of the C4 and of course remove the cross member, drive shafts and linkage can I leave the adapter attached to the transfer case and slide them back/off as an assembly to change the gasket? Any tips on reassembly to make sure it is leak free?
