6r80 to atlas II adapter. Is a gasket or RTB needed?
strebel
Newbie
May be a dumb question. Is any RTB or a gasket needed on 1 or both sides of the 6r80 to atlas 2 adapter? None were shipped so I sort of assume not needed?
Yeller
Rogers County Oklahoma
Your welcome. Wasn’t meant as a correction just being clear and did understand what you were asking. We all do it, spelling, punctuation, auto correct you name it. Been following your build, it’s going to be nice!
strebel
strebel
Newbie
Will be attempting to mate the body to the chassis soon. Just mocking up the twin stick shifters off the atlas right now.
jamesroney
Fremont, CA
RTV is an appropriate sealer for those surfaces.
I though that the 6R80 was dry between the transmission and transfer case. I'm almost certain. The one on my Coyote was that way. It was a D20 adapter, but I think they are the same. The only tricky thing is that one special socket head screw that's counterbored in the bottom.
I know that the Atlas is dry on the input side. It has an input seal, but it's usually double lipped.
I would worry much more about how I would keep the splines lubricated. @nvrstuk will know this off the top of his head.
nvrstuk
PNW
If people mentioned my typos that's all that would be posted! My latest "auto-download" on my phone (which I couldn't reject) changes about 1/3 of my technical jargon changing them into words that don't make sense for the rest of the sentence. Frustrating at best when I go back and re-read a day later and "converter" is changed to "assumption" and I go WTH???
Anyway, it's dry! :) I just coat the splines with anti-sieze so I can be covered with it later when I install it. :) I have never seen any lube on the splines when pulling factory installed 6r's apart. Guess Ford's saving 10 cents by not doing it. Here's a pic of one sitting next to a stroker... waiting for a home someday.
Yeller
I too believe they are dry, I happen to like them to be sealed up. Mostly keeping water and crap out causing corrosion. As for lubing the splines I don’t feel that is that big of a deal, Heeps were that way for a long time with a weep hole that let all sorts of junk in there without any real negative side effects other than killing the seal and making a leak.
nvrstuk
PNW
So there's a build thread somewhere on this? Can someone post a link? Thx
nvrstuk
PNW
Yes, I can use my t v remote but to give you an idea, we've had our tv for 4 years, and just three days ago I figured out how to do slow motion.... that's my preface, for there is no signature line on strebl's post so so I can't figure out how to get to his posts.. at least it's not showing on my phone! lol
Yeller
we aren't that far apart in the tech department 😂
the vertical vs horizontal phone thing comes up couple of times a year. I stumbled on it by accident, how we accomplish amazing things.... by accident :ROFLMAO::ROFLMAO:
kman67
Aptos
In order for me to see the signatures on my iphone, I switch from the Tapatalk app to web view, then go horizontal.
nvrstuk
PNW
thx. My desktop is fine but phone not so much (and I"m sure it's me because it's a new Samsung). lol
