I am nearly done with a frame off 72 restoration and I have just started the beast for the first time in 2 years and this is what I see.h
It starts in in park( I think) but the rig wants to move backwards so I believe that the neutral safety switch may need adjusting. Can this be, the only adjustment I see is the shift linkage and I beleive that is OK.
I also think I put too much transmission fluid in the C4. is there a way I can drain some out? It may be that the fluid has not worked its way into the troque converter but the stick still reads over full.
I was also wondering if there could be a connection between the transmission being too full and it wanting to go backward at start up in park.
Thanks in advance.
Steve72
Thanks in advance.
Steve72
