treihesse
- Aug 1, 2008
- 1,459
I have a health 408w. It was in the bronco with no specs.
Afr 205 heads
Howard hydraulic roller cam
Lunati 1.6 roller rockers
Airgap intake
Fitech
No information on lift or compression but i assume 10-10.5-1.
Trans is a c4 and is not happy
Going to rebuild transmission 1st.
Sonnex servo.
Broder reverse manual valve body
Alto reds
B&m pan
WHAT STALL RATE?
Uses is rock crawler and occasionally sand bowl. Minimal sreet drive.
4.88
Atlas 4.3
500+hp
39 tire
Afr 205 heads
Airgap intake
Fitech
Sonnex servo.
Alto reds
B&m pan
WHAT STALL RATE?
4.88
Atlas 4.3
500+hp
39 tire
