crab
- Feb 23, 2004
- 2,268
So, this C6 has seen some abuse. Many of you have seen the you tube videos of my bronco pulling full size trucks out of the mud and broncos out of the snow. The rest of the time it is bombing the dunes with very little pavement miles. The original build (427stroker/C6) had about 6k mikes in it over the past 10 or so years. Last year, I put a TCI reverse manual valve body and winters gate shifter in after bypassing “N” and shearing the park pin. I really like the RMVB, but the trans overheated If I didn’t turn on external cooler even down the HWY. I finally lost second gear a few months ago and the bronco is back down at Cordrays in Albany (they have done all the work since the beginning). They’re not sure why it’s only second gear and everything else is firm?? The current valve body does NOT have braking which I really want but was told it will build even more heat. Any suggestions or recommendations? This is what I’m looking at:
https://broaderperformance.com/product/c6-reverse-full-manual-valve-body-w-brake-in-1st/
