eds66bronco
so i've been working on a buddy's bronco doing a bunch of axle/brake upgrades and went to take it for a drive to get the cage done. i don't know much about auto trannies so i'm not sure what is wrong. i pulled out on the road and it seemed to do the 1-2 shift and reved up til my speed got to about 30. at that point, i was close to redlining it so i pulled over. tried again and same thing. got her back home and did the following...
things i checked:
1 pulled vacuum line off modulator to check for leaks -none
2 checked for vaccum leaks on line - none
3 checked fluid level of tranny - right on the mark/not burned/good color
4 put up on blocks and shifted through detents by hand to eliminate shifter linkage - same results as road test. maxed out at about 30 (redlining motor)
5 manually downshifted from D to 2 to low and back up again while driving - felt good solid downshift
6 tried to get it to shift by letting off the gas - didn't work
7 tranny feels good shifting from park to reverse and into drive
what am i missing?? man this auto tranny vodoo suxxxxxxxx
things i checked:
