C6 tranny help
eds66bronco
Essex, Vermont
so i've been working on a buddy's bronco doing a bunch of axle/brake upgrades and went to take it for a drive to get the cage done. i don't know much about auto trannies so i'm not sure what is wrong. i pulled out on the road and it seemed to do the 1-2 shift and reved up til my speed got to about 30. at that point, i was close to redlining it so i pulled over. tried again and same thing. got her back home and did the following...
things i checked:
1 pulled vacuum line off modulator to check for leaks -none
2 checked for vaccum leaks on line - none
3 checked fluid level of tranny - right on the mark/not burned/good color
4 put up on blocks and shifted through detents by hand to eliminate shifter linkage - same results as road test. maxed out at about 30 (redlining motor)
5 manually downshifted from D to 2 to low and back up again while driving - felt good solid downshift
6 tried to get it to shift by letting off the gas - didn't work
7 tranny feels good shifting from park to reverse and into drive
what am i missing?? man this auto tranny vodoo suxxxxxxxx
eds66bronco
eds66bronco
Essex, Vermont
forgot to add he has a hurst pro?? floor ratchet type shifter. cable works correctly. no kick down cable but he has never had a broblem running without it.
i feel a tool throwing hissy fit setting in!
eds66bronco
eds66bronco
Essex, Vermont
Update:
last night, i rechecked everything again. removed vacuum lines and blew out with air hose, pulled the modulator (looked good and post moved with vacuum) no leaks so i reinstalled. hooked it all back up and it went right up through the gears.
not sure what i fixed but i did.
note to self: don't grab the hot exhaust pipe while sliding out from under the truck on the creeper. it hurts :(
