cage to frame
Bronkster
I have a 6 point Crab Cage that I really like. The only thing I would do different is that I would have ordered it for no dash pad for a little more clearance. I want to tie it into the frame and was wondering if anyone has done this or has suggestions on taking out some of the head scratching to fab something. I have a 3" body lift. Thanks for any help!
Steve83
There's no advantage in eliminating the body mounts (hard-connecting the cage/body to the frame), but there are DISadvantages (noise, vibration...). You get more benefit by connecting the seats & belts to the cage, and letting the body rip off the frame, if it gets to that point. That way, you & your passengers stay with the light body, and all the heavy/flammable stuff goes somewhere else.
B
Bronkster
soooo you're saying to just use steel plates and sandwich the body and not worry about tying it in to the frame?
Pretty'LilThang
Davis
I like how my cage to frame mounts stiffened up the body flex, made everything feel a lot tighter. By using bushings in the cage to frame connection you aren't eliminating the body mounts therefor you aren't adding significant noise or vibrations. Yes there will be a little bit more due to the poly bushings being a little harder then the stock rubber body mounts, but it is on a 30+ year old truck it is already loud. I doubt you will notice a difference in the noise level
NC-Fordguy
Bethel/Greenville NC
I madw ties in from the frame to a plate on the underside of the floor. This plate was bolted to the plate on the inside of the bronco.
I used some 1.75 in .120 wall dom tubing and tabs. To allow some flex for body roll I used shackle bushings I got from napa ... I think it was for a cherokee chief. A little silicone spray inside the tubing and the bushings slipped right in
Steve83
I wouldn't even do that - just a simple attachment to body is enough. You're not trying to protect the body, or make the truck more rugged; the purpose of the cage is to protect the occupants after the truck is destroyed. So build a strong cage & attach the seats and belts. And if the body breaks away from the frame &/or cage during the rollover, let 'em go. They're not helping you at that point, anyway, but they could hurt you if you keep them close.
By using bushings in the cage to frame connection...
I think that's VASTLY better than welding/bolting the cage to the frame, but I also think it's redundant. There are already rubber body mounts, and adding more doesn't really help you - it just adds cost & weight. If you tie the cage to the factory body mounts, you accomplish the same thing, without that cost or weight. But even if it's not tied to the body mounts, it'll still do what it's supposed to do. Look at how the cockpit capsule ejects when a racing boat disintegrates - that's all the cage needs to do.
RustyShackelfor
Centerville, TN
You say that like adding a heavy second moving object doesnt carry risk. If the frame and body separate, you have the frame/motor/axles/etc... that can then come back in contact.
Steve83
There are an infinite number of directions those lost parts can travel, so it's pretty UNlikely that they'll come back to you if they're not attached. I prefer that SMALL risk to the relatively high one that smaller chunks breaking off will come inside the cage. If the big pieces get near you again, they probably won't fit into the cage, so you'll still be safer.
But this is all worst-case. In all likelihood, it'll never matter either way. Most vehicles (even those specifically built for off-roading) never roll over.
B
Bronkster
Thanks for the input, this rig is wheeled pretty hard in large dunes and I have seen how well the floor boards hold up with nothing attached to them...so I will look for a way to anchor at least 2 of the legs to the frame. Battlement fab, if you come up with something keep me on the list of those interested.
Greg_B
Cohutta, GA
I agree with Steve on this...
If you are rock crawling and are constantly in danger of a low speed rollover where you would want to just flip it back over and fire it up then of course you would want to attach the cage to the frame and minimize structural damage... cosmetic damage... who cares right? You are wheeling...
Now if I am travelling down the road in a daily driver with my wife and kids and the chance of a high speed rollover is more likely... I do not want my cage tied to the frame.... If I am going to flip over and roll at 50mph plus I (me and my family) want to survive... the EB... who cares... it is replaceable... I want that frame, engine, fuel tanks and oil to get away from me not be bolted or welded to me. So I am going to simply tie the seats and belts to the cage and if I roll (God Forbid) my family and I will stay in the cage and the rest of the truck can go where it wants.
Yes there is the chance the seperation of the frame from the cage could mean they come back together at some point but I still think I want to "hope" I get away from it instead of "making sure" I stay with it.
That is my logic anyway... I probably confused everyone...
Greg
Galt72
Been a cop for 30 years and seen hundreds of high speed crashes. You definately want to stay in the vehicle. I could only imagine what I"d find after a cage went sliding/flipping down the highway bouncing off other cars,trucks,trees,center devides and god knows what else.
Bought the hoops from Complete Offroad. not sure why they arn't listed on this page anymore.
http://completeoffroad.com/c-59816-roll-cages-accessories-roll-cage.html
http://polyperformance.com/shop/Synergy-Suspension-Cage-Tie-In-Kit-p-433.html
jim3326
Appleturkey
I would agree with Galt, I would think that a NASCAR concept would be better where every piece that breaks, dissapates energy. If you wreck hard enough to rip the body from the frame everyone inside better be wearing a firesuit with a 5 point harness and a HANS device if they expect to survive. And that is based on having a full enclosure roll cage for all occupants, IMHO.
Jim W.
Greg_B
Cohutta, GA
What does tying it to the frame do for you vs tying the seats into the cage?
I have tubes ran across the floor front and back and all the seats and belt connected to the cage.
I am not sure what is gained by tying it to the frame. Stiffness?
I am more worried about the steering wheel being pushed into my chest in a front crash than anything else.
Greg
Steve83
Yeah, the most dangerous thing inside the cage is the steering column.
But I'd want to let the chassis go even in a low-speed wheeling roll, if the roll is severe enough to separate them from the cage. Scalding coolant & oil; gasoline; a 1000CA battery filled with sulfuric acid; I'd rather they all go their own way, and let me & my passengers go ours.
Fortunately, my only roll wasn't that bad, and my '83 doesn't need an extra cage anyway. It's rollover rated from the factory.
399strokerEB
Wasilla, AK
I thought the purpose of tying the cage to the frame was to keep the cage from pushing through the floor and squishing the occupants if you flop on your roof?
SDlivin
San Diego
Good point, maybe thats why some cages have full internal hoops from roof to floor.
