Bronco Wild
I have my Bronco almost completely sanded down to bare metal. This is my first time going the POR route so I would like some input and suggestion on direction at this point. My next step will be Metal Ready then POR the whole rig. Here are my questions and consider I had quite a bit of rust, still in some places and cut and welded in new pieces in the larger areas.
1) POR 15-Silver or Black? Silver has metal filler in it which I suspect I need in my situation. Anything to consider as far as sanding, then priming? They say wet sand with 600 grit before priming?
2) Seam sealer. What kind? Eastwood has gun or brushable, which is recommended? I am Herculining my tub after POR and seam sealer. Does Hercliner adhere fine to POR?
3) Body Filler. This Bronco isn't my "show truck", so the old fenders that are near shot are going to be salvaged one more time. So I have heavy filling.
POR Straightline, Eastwood (Evercoat-Rage)??? Any secondary or finer fillers?
4) Primer. POR Tie Coat or Self Etching?
Recommendations other than this as far as sanding POR and/or primers?
Thanks!!!
Thanks!!!
