Calling all EXPERTS!
Bronco_007
Nature Coast, FL
Yes, that means YOU! You’ve just been promoted to expert!
I need advice…
My baby blue is a 1974. Stock 302, stock three on the tree. 235/85R16 KO2s (31.7/9.3). It has stock 3.50 gears.
I’d like to re-gear front and rear and will likely update the tranny in the next one to two years. The engine stays, it only has 66k miles on it. With a rebuilt original carburetor.
I spend 75% on road, 25% off road.
The age-old question presents itself: what tranny and gears for my engine and tires?
I’m thinking 4.11 front and rear with a Detroit Trutrac in the rear. And I’ll likely go with the AX15 in the future when I make a big transmission swap or have to do any major maintenance on it.
EXPERTS, opine!
Timmy390
Conway, AR
4.11's with Truetrac in rear, 33's and just went M5ODR2. Couldn't be happier. 95% street and it's great. Overdrive is VERY usable on the back roads just cruising.
In no way saying my combo is the best as everyone likes what they like but I'm super stoked about my setup.....I do bump a 351W with a torque cam, good heads and EFI. I'm sure that helps my combo become one with the Force........
Tim
Bronco_007
Bronco_007
Nature Coast, FL
Tim
The Force is strong with us, Tim.
Rustytruck
I have 33" tires with 4.11 and if I had your truck I would do it all over again but I use a detroit soft locker in the rear and a tru trac in the front. since your in Florida you have no snow to deal with. so you can add traction aids. at minimum I would do tru tracs both front and rear. with 4.11 you can use thick cut gears in the front so you don't have to by a new carrier for the gear split. At the rear if you changing the carrier to a tru trac then you have to decide if your running the stock 28 spline axles or upgrade to 31 spline axles I personally have my stock 28 spline axles running the Detroit soft locker and an automatic transmission for over 20 years. just depends how hard you want to play and what risk's you want to take.
Timmy390
Conway, AR
I did upgrade to 31 Spline rears after my factory limited slip split in half. That was just after my W went in and I was running 32's at that time. I have a Dana limited slip up front.
Tim
BOBS 2 68S
Hudson, CO
I am running a Blue Print 302, Holley carb AX-15 trans, 4:11 gears and stock sized tires. Very happy combo. Just pulled my 1970 Cardinal camp trailer camping and fishing over a 10,000+ foot pass and got 13.14 mpg
Bronco_007
Bronco_007
Nature Coast, FL
I’ve not heard of the soft locker. I’ll look it up!
Rustytruck
its just sprung a little differently so its not as harsh locking up virtually no banging into lock up unless you throttle around a tight corner. a lot better manners. I also put one in my 4 cylinder tacoma pick-up it wasnt as midley mannered. may be truck was too light?
