OK, thanks everyone. Why do I feel like I opened a huge can of worms? Major engine work is NOT in my skill set yet- I'm not even entirely sure what the timing gear/chain is. Am I getting in way over my head? How does one pull a motor, or is this all ok to be done with the grill off? My Bronco is in pretty good shape- it was a low mileage arizona forest service truck. I'm doing this mostly to get proper performance at altitude.
If your car has larger than stock tires, that could be the reason it's poopy.
I went the same route, and went cam, 4bbl, better heads, and headers, and it was still poopy.
After re-gearing to compensate for the tire size, I got the performance back. In fact, many times I wish I had left the stock motor alone.
But then there are moments when I just can't contain the little boy in me.;D
If you're on this forum much, there seems to be a consensus that the factory 2bbl carb is perfect for normal driving and trails. It may come up short when trying to pass on a two lane highway, but other than that it works great.
