Starting the tear down process to change a water pump...
Might as well do a timing set while in that deep. And if I am in that deep I might as well do a cam swap...
You all know where this is going.
Is it possible to change a cam with the engine in and he grill in place?
Next and probably a tougher question. Is it worth changing a cam on a box stock 2V single exhaust (w/cat and air pump) motor.
It’s a survivor grade 77, C4, 3:50 gearing, 31” tires.
Idle to 3K power increase and a smooth idle are the goals.
Thoughts???
Thoughts???
