Yes, there are shims that go between the knuckle and the spindle. This is how you adjust the camber. The way I've done it was to take the Bronco to an alignment shop, have them see what the camber angle is set at and then buy the correct adjustment shims to correct it. I ended up taking my shims off and then took it to the alignment shop for a base line check. I was lucky I guess because it fell right into the correct specs.
If you do find that you need shims, make sure you put them on corrrectly.
Good luck
