chriswitt
- Nov 26, 2009
- 191
Anyone know what the camber spec should be for EB? I just had my Bronco aligned and my camber is 5.5 on one side and 5.75 degrees on other. I notice that the bottom of my wheels are slightly in and the tops slightly out. I have seen shims that go behind the spindle and have also seen some sort of offset that threads in at the upper ball joint to offset camber. Anyone have an opinion on either way to correct camber?
