Camber settings
jmangi62
Hey guys,I just got back from the alignment shop and I need more camber,the toe was good,I have long arms and just ordered new c bushings to get the Caster back where it should be,but my question is how do you get more camber? My left front is 4.7 and the front right is -4.5. I know, I know, it's bad, she pulls to the right pretty bad. Thanks. Jim ?:?
Digger556
Check your numbers again.
Mid-4's reads more like a CASTER number. Factory CAMBER was 1.50°.
If your left camber is 4.70° and right is -4.50°, something is severely bent and the truck would be pulling to the left like crazy.
Can you post a picture of your alignment printout?
blubuckaroo
Grease Monkey
Ridgefield WA
You have several options.
There are the tapered spindle shims made for that, and the eccentric ball joint nuts.
But a good chassis shop will usually opt to bend the axle tube on the alignment rack. This is the best method since it actually fixes the reason for the misalignment. My '77 came from the factory with so much positive caster on the passenger side that you could actually see it. That tire would only last 5000 miles. The chassis shop chained it down and used a hydraulic jack to straighten it. Now the front tires wear just as flat as the rears.
In my experience, the ball joint eccentrics will correct the alignment, but at the expense of an improper ball joint pre-load.
jmangi62
jmangi62
WOW! Thanks brother! He did mention something about "do you have any shims in there!".
jmangi62
jmangi62
OK So Blu, should I take it somewhere like a frame shop? They may have the ability to do this. I'm not sure if this particular shop could do this, I guess I could ask him. Sorry bout the sideways pics, I either get them sideways or not at all, I just can't win lol. ?:?
migs
can you post a picture of the truck from the front?
I would think with those camber numbers the tires would look drastically tipped in and out....like a circle track car or something.
jmangi62
jmangi62
Hey brother migs, how the heck are ya? You know he said the toe is good, the caster? and of course the camber is shot lol. I'll back her outside and take a couple pics then I'll post them, give me a minute. Thanks guys. Jim
jmangi62
jmangi62
OK Here we go.
jmangi62
jmangi62
More pics. ;)
toddz69
I would think, as others have noted, that if your caster was really that bad that we would see it (I had about +1.5 on my EB for years and I could visually see it).
Todd Z.
blubuckaroo
Grease Monkey
Ridgefield WA
Yes, chassis shops and alignment shops are different things altogether. Look for a place that works on motorhomes and medium/heavy trucks.
Those places have a better understanding of the types of suspension on older 4X4s.
migs
Doesn't look too bad in the pictures, I would've expected to really notice it based on those numbers. Being one negative and one positive of almost the same value makes me picture dropping one tire in a hole and taking the readings.
You can rough check it with a digital angle finder quick and easy enough. Make sure the tires have equal pressure, park on a flat surface, zero the angle finder to the floor surface then check the readings on top of the hub and against the side of the brake rotors. Should show you something in the ballpark of what it actually is.
jmangi62
jmangi62
Yes, thanks guys I really appreciate your expertise, you know I think I'm gonna do what blu said, we have several RV shops here and a good chassis/ frame shop so I should be able to get it dialed in. Yea migsy my freind, you can't see shit lol! It looks good, that's what puzzles me cuz she pulls hard right just going in a straight line. ?:??:??:?
migs
Some added caster is probably not a bad thing, but at the expense of your pinion angle. And if there truly is an issue with the camber, make sure you eliminate any possible issues with replaceable parts first such as ball joints and knuckles or bent spindles before you go and have the axle housing bent to try to correct it.
jmangi62
jmangi62
Hey blu, where on earth do you get ball joint eccentrics? And tapered spindle shims?
Slednut10
Guru? That's funny!
If the camber numbers you got were true, it would look like a road grader going down the road as one tire would be noticeably tipped out at the top while the other would be tipped in about the same amount. Mine had 1.5 degrees positive camber (top sticking out) before I installed shims and it was noticeable.
jmangi62
jmangi62
You know bud,I think the spindles are brand new, but the knuckles are from the used front axle, maybe those aren't exactly straight?? All the brake parts are brand new and ball joints are moog,brand new. :-[:cry:?:?
