Original spec was 1 to 2 degrees positive camber. With the 1.5 degrees broncodriver mentioned being considered the optimal setting. But what the others have said is all true. These things seem to work better with less than 1 degree. Getting it down to a half to a quarter degree seems to be a sweet spot.
Caster was 2.75 to 3.25 in the early years, 4 to 6 later when power steering was ubiquitous. It's a pretty rare '75 or earlier EB however, that can achieve that with normal methods. Probably didn't even have it from the factory. Cut-n-Turn is the only solution for the worst offenders.
Full-size Broncos got 6 to 8 if I remember correctly.
If you're still running manual steering, your options are fewer. But if you do have a good power setup already, try to get 4.5 to 6 degrees positive caster if you can. Really anything over 3.5 on an EB is a coup if you can achieve it!
Toe-in seems to follow factory recommendations for most of us, at between 1/16 to 1/4 inch. With 1/8" being optimal. That's worked for me with every tire/wheel combo I've had.
However, there are a few running "toe-out" settings now, which also seem to be having good luck with it. Can't remember exact numbers at the moment, but there was a discussion about it last month I think it was.
Offset ball-joint collars, tapered spindle shims, C-bushings and radius arm drop brackets are the most common ways of getting caster, camber or both. Many of us run multiples of those, and even a few all-of-the-aboves running around.
When trying to correct caster you still have to be mindful of the pinion angle and not biding up the front u-joint.
I know you were talking about camber only, but I figured it was good to put all the categories on the table while you're messing about with yours.
Good luck.
