I have a 302 with a manual 3 speed. I drove it to work today (about an hour) and close to the end of my trip I heard my throw out bearing squeeking/knocking. I could put my foot on clutch pedal and feel it vibrate with the noise I was hearing. When I got to work I had it in neutral and revved engine...no noise.
Coming back from work the noise got worse and worse. I never had to change gears but still like before, I could rest my foot on clutch pedal and feel the noise it was making. When I finally had to slow down to change gears when I pushed in the clutch the engine shut off. I didn't hear a loud pop or anything unusual other than the racket of the throw out bearing. I coasted to the side of the road and try to turn the engine over and the starter is making a loud click but the engine is not turning over. I can put the tranny in neutral and the Bronco will roll. I put the tranny in a gear and it will not roll. Tapped on the starter a few times until my buddy came and picked me up but still nothing. Starter didn't feel warm at all. So the ol girl is sitting along side the road right now and going in the morning (with daylight) and try to take starter off and see if I can turn engine over with a pull bar. I"m HOPING the throw out bearing has something jammed up but I have never encountered something like this. In the past when bearing goes the clutch pedal hits the floor and you have to limp home in what ever gear you can get it in...Any help will be great...thanks
