I know it's different software and a completely different engine but if you don't control the variables, it won't be happy.
Here is my fuel when in idle state:
All based on load and RPM. I also allow 0 EGHO Authority (O2 sensor doesn't matter and ecu can't adjust) under 1400 rpm and ramps up to 10% authority at 2000 rpm, meaning it can adjust up to 10% fuel in either direction at that point.
As far as enrichment is concerned, you need to mess with it until you find a spot that it seems happy and go from there but 236% is a shit ton of fuel. And that's at what temp? I have mine set to be 199% at 30 degrees but my Bronco has never seen 30 degrees so not sure if that's good or not but it should be based on the curve I was able to establish. At 50 degrees I'm at 169%.
Here is my curve. Not perfectly smooth but makes my engine happy this way.
Timing:
Do you have an idle timing correction curve in that software? Pretty sure I had to disable mine while tuning but wherever it's happy at warm idle
For air, tune this when warm if you have the ability to set your IAC valve and see what the engine does when you set it. That way you know the numbers that do what and your ecy isn't fighting to find the spot.
Not sure if you need all that but maybe something to look at. If it runs well once warmed up, then these are the things you need to focus on. Log every start and take notes when something seems good. The first minute or so of an O2 sensor reading is worthless. Trust your experience with what you think the engine is asking for or try giving it more fuel, then less fuel, more air then less air and see what it does. It's most likely going to want the same amount of ait cold as it is warm at the warmup rpm you want and it's going to want enough fuel to make it happy and more rich than warm but not overly so. My engine is happiest warming up at 12.5 afr...or that's the reading I'm getting. If your cam is lopey, then it's not necessarily an accurate reading either. It just is what it is so listen to the engine and go both directions.
Been a while but I think I liked this video I bookmarked a while back but not sure if that's the one that would help.
