So, I noticed when I pulled the rear driveshaft from my '72 that it doesn't have the CV/Cardan joint on it. It does have the Cardan joint on the front driveshaft.
Anyway, now that I'm reassembling stuff, removing and reinstalling u joints, etc. I'm trying to figure out what's going on here.
The driveshaft appears to be original. It's maybe 1/2" longer than the shaft that I took out of a '66 6 cylinder Bronco.
Would the original shaft be long enough to work on an unlifted '72 with small tires if there was no Cardan joint installed? It would seem to be several inches shorter than stock, right?
My plan is to purchase a Cardan joint and all new 1310 Spicer u joints and re-install, but wanted to check with the brain trust here first.
Also, is there supposed to be something that prevents the splined end of the shaft from sliding through the splines and whacking the u joint?
Thanks,
Scott
Thanks,
Scott
