1970excursion
- Sep 16, 2010
- 307
Is there a way to test oil pressure without the engine running?
cranking it by hand work?
Do you know exactly how fast your drill spins? To properly diagnose oil pressure you would need to know what RPM your spinning. Yes that's a way to get oil pressure but a weak pump will make good pressure high rpm's yet hardly put out anything at an idle. Kind of hard to duplicate with a drill.
The actual oil pressure an engine will experience running cannot be known to even a rough degree without every rotating part spinning in its journal bearing.
The spinning in the journals has nothing to do with the pressure generated..
Not with a Ford pump. With a gear-type pump, like most GM, rpm has a direct effect on output. Ford's use a gerotor pump, which is a positive displacement pump. .
..engineer here.
Yea...that pretty much sums it up. :-*
How about this...go run your engine and check your oil pressure. Now pull the distributor and drive it with a good 1/2" drill. Tell us what you see. Talk about it all you want. The horse is dead...beat it for all I care.
Sheesh guys. %) The original poster asked if it could be done. It can.
No offense intended in my original posts. As for the engineer...yea, I don't really care.
Not with a Ford pump. With a gear-type pump, like most GM, rpm has a direct effect on output. Ford's use a gerotor pump, which is a positive displacement pump. They put out 80-90% of the pressure and volume they will generate at only 1,500 rpm pump speed. That is why you do not see a linear, continuous increase in pressure vs. rpm with a gerotor pump, like you do with a standard gear pump.
Bill I already said you were right, You don't have to make me feel stupider will all the fancy words.
