Triggerman said:
Thats a good posibility the drums were faulty-rusted-fractured, whatever. Fact is something like this could happen w/ front drums so I wouldn't risk it. There are just too many advantages of front disk over front drums that have been hashed out time after time over the years on this and other lists.
Don’t think that disks are any better then drums as far as failure. I have seen a rotor snap off of the hat and just flop around inside the wheel. Wasn’t due to wear, neglect, abuse, corrosion, etc. That was with a little P235 tire as well.
I have also seen caliper bolts fall out. Sometimes the caliper stays on the rotor, but not usually. Usually it just slides around inside the wheel making bad noises. Sometimes it catches the wheel and just brings that wheel to a complete stop, right now!
As for hydroboost vs. disk as the first brake system upgrade, it depends on what I want to fix first. If the pedal effort is the problem go hydroboost. If fade, strange pulls under braking, inability to stop after driving through water or everything up front is just wore out then do disk first.
What problem do you want to tackle first?
