Cannibalize an Expedition?
sirius23
Cumming, Ga
I've had my 77' for 5-6 yrs now. Looking to make it more of a daily driver by putting in a new crate engine, EFI harness and whatever front end solution necessary to tighten up the steering. Most of these changes are driven by the fact that my boys are growing up and I'd be a lot more comfortable with them driving it if these things were addressed. I'm comfortable with letting it "drive itself", i.e. not fighting the wheel, but I'll always remember the first time I drove it and experienced a mild sense of fear :) That said, I've had all existing steering components looked over and the general consensus is that 'perfect' steering control can only be achieved by modernizing to a front end off of a more contemporary vehicle. This brings me to the revelation, that's totally going to expose me as a newb in the wrench dept, that I have a well maintained 2000 Expy 4x4 that's currently worth more to me as a driver than something I'd ever get any resale out of. SO, how much of the Expy can one cannibalize into a 77'? Front end? 5.4 L Triton? EFI harness? Am I reaching here, or is there an opportunity?
Justafordguy
Anything is possible but It's going to be a tough swap because the 5.4 is to wide for the EB frame rails. You would be much better off finding an Explorer with a 5.0 v8 and using the drivetrain from it.
surfer-b
X2^^, before I tried anything I would return the Bronco to stock height with a good suspension system from one of the vendors, install a set of sway bars, and 30x9.50 tires. This will make a huge difference if everything else is correct, tie-rods, ball joints and steering box, in the way it drives/handles. These things are never gonna drive like a new car, but they can be made to drive nice.
If you are wanting to do a conversion like a modern 4x4 I would look into the suspension system of the new jeeps and copy those, yes they are both coil spring systems but the jeep is a 5 link setup with a sway-bar. It would be much easier and cost less than trying to swap the Expedition or an Explorer into the Bronco.
sykanr0ng
Leave the Expedition as a driver.
Have your kids drive it.
You can improve an early Bronco, but it will never be a modern truck.
Your boys are not experienced enough as drivers for a classic car or truck yet.
Expedition is a poor donor. Nothing is close to fitting right. Not only is the engine wide, it is tall. So many other choices that fit better, and plenty of those are bad as well.
Ryan_M
Franklin
I learned on and my first car was a '77 bronco at the age for 14 ;)
lsukevinc
Holly Springs
if you want more power than the 302, go 351 route out of a 90's ford. The triton engines are huge compared to the 302 and even 351.
