marty
ok so i have been trying to figure out why my engine does not run well upon cold start but i also am having another problem on and off. i am getting a solid check engine light even after the engine is warm. sometimes it goes out quick sometimes it stays on for 10 plus minutes. what it is code 66 vaf/mass air flow sensor fault below minimum voltage. i have tested the sensor and it comes back as saying it's good. i have days where i can run this thing for 25 plus miles on the highway and it runs great come home go back out 15 minutes later and boom light comes on for either a few seconds or stays on for a length of time. but now comes the other issue which is i can run a koeo test come up with codes clear them and then run the same test and get the ususal codes 67,81,82,85,84, and then code 11 system pass which you need to get to run a koer test. when i run that test the engine sucks in some air through the mass air and you can hear the engine rpm change up and down a bit but it never lets me see any codes or such. i have even tried doing a cylinder balance test and it does the same never comes up with the results. these test are being done with 2 different scanners also so it's not the scanners. i have tested the dlc plug as per the test in the snap-on scanner book and it comes up good. this is driving me crazy. i have checked grounds on the rjm harness also checked power cannot seem to find anything. anyone have any insight to help a brother out before i roll this thing out on the highway and light a match. i am at wits end here. any help would be greatly appreciated.
