Engine is a 93 5.0 HO MAF from a 93 Mercury Cougar. Everything is OE and I reused to OE wiring harness from the cougar into the Bronco-ran fine for years. Recent running problems has me checking codes. I did not rewire the OE check engine light so I'm using a jumper wire (from Self Test Input to terminal 2 of Self Test Output) AND a small indicator light from terminal #4 of the STO to pos side of battery to do the test. I can successfully pull Key on engine off (KOEO) codes but after I pull those, wait 10 seconds and start the engine for the Key on engine running (KOER) codes I get nothing. No 4 flashes (indicating a V8) or anything else. I even tried grounding the Self Test Input (STI) to see if that would help but sill nothing. That did still allow me to pull the KOEO codes but not the KOER codes. Any ideas??
