So are these AFR heads on my 347 stroker canted heads? Never thought about it before.
Randy
Oh no...The dreaded "Canted Valve" discussion.
There are three relevant definitions for the words "Canted Valve."
There is the dictionary or literal definition for the two words individually. "Canted" and "valve."
There is the Ford Marketing and branding definition, and the corresponding group think.
There is the NHRA competition rules for valve angle. "Canted" versus "Splayed" vs "Wedge"
The literal definition of canted means that something is slanted, tilted, or oblique, between two things. So you can have a canted window, or a canted roof, or anything that deviates from true horizontal or vertical.
In 1968, Ford unveiled their Tunnel Port cylinder head for the 5 Liter Trans-Am racing class. That head had the PUSHROD (thx broncobowsher) sticking right thru the intake port. The head was modified for 1969 and the valve was moved and tilted. This cylinder head was installed on the Ford 302 and became the "Boss 302" which dominated the 5 liter Trans Am racing series. It was known to have "Canted valves" That valve arrangement was later applied to the 1970 351 "Cleveland" engine. And the Canted Valve legacy persists to this day. It is worth pointing out that the 1965-1/2 GM 396 was earlier than the 1968 Ford version...but the Big Block Chevy version suffered from reliability issues, but those have long since been resolved. Since SOMEBODY neeede to be able to describe WHY the Boss302 out performs the standard 302...The legend says that the Boss 302 used the 351 Cleveland head. Obviously, that's absurd, because the Boss 302 pre-dates the 351C by a couple of years. But it's really chicken and egg. The "new" head was being developed for the new engine, and was fitted to the old engine. So when anyone asks what's the difference between the "Windsor" and the "Cleveland" the answer is that the 351C uses "Canted Valves."
The NHRA competition rules make a further distinction between "Canted" (one valve at an oblique angle) and "Splayed" (two valves at oblique angles) and "Wedge" where both valves are in-line relative to the crankshaft center line. All modern 90 degree V8 engines have some kind of angle between the valve and the cylinder. This angle forms the "wedge." As soon as you rotate or "twist" one of the valves, you have a single valve with an angle tilted fore-and-aft and side-to-side. This makes for a "twisted wedge."
NHRA makes the distinction only so that competitors can have a common language. The language is just used so that there can be a "difference." So in NHRA speak, "canted" means one valve tilted fore and aft...and "splayed" means two. This means that the TFS twisted wedge head is a "canted valve" head, even though TFS does not recognize it that way. The factory 351C head is "canted" on both intake and exhaust, so the NHRA calls them "splayed" and "NOT canted." This makes for much confusion, because twisted wedge heads, which are canted, are not canted...but Boss 302 heads, which are also canted, are not canted.
None of that matters with respect to performance, because as we all know...the GT40 wedge heads can flow just as well as the 2V 351C heads, which flow vastly better than the Chevy 454 peanut heads. And nothing flows like a Mopar Hemi Head.
So...in 1969, if you had a Boss 302, you were the king of the street. In 1971, if you just got your 350 Chevy SMOKED by a 4V Ford 351 Cleveland...and you wanted to know why, the answer was the same: "Canted Valves"
