brbuilder
- Joined
- Aug 19, 2007
- Messages
- 176
'69 302, Holley TA 470, Performer intake, Cardone Electronic Dist & 4-Pin Module
After sitting for several months started it up and had issues, flooding. Cleaning the secondary bowl needle and seat cleared that up. Got it running but had to advance distributor to 30 - 35 or it just cranks but won't fire. Once started I could dial the timing back to about 10 but if I shut it off it will not restart unless I advance the timing to 30 - 35. Idles about 900-1000. Accelerator screw is all the way in. Idle mixture screws are about 1/2 to 1 turn out. Vacuum around 19 - 20 at that 900 - 1000rpm. In the garage, engine would rev good without the vac advance but would backfire through the exhaust if the vac advance was connected. Runs rich, new Autolite AP45's. Pulled the plugs and 1 was clean, 2 were light grey and the other 5 were black.
I've been adjusting timing, mixture screws, new gas. I tried a Motorcraft Duraspark ICM (Amazon) but the wires powering it and to the e-core coil got really hot. Does this ICM need to be attached to the body (grounded) to work properly?
Any ideas/help would be appreciated. Thanks
