Carb questions
jckkys
I don't do much more than rebuild Q-jets, I have seen AFBs that have the step up piston stick in it's bore, especially in hot weather. It doesn't make sense since the piston and bore would expand equally as they are the same material and temperature. Edelbrock's tech line "experts" couldn't explain it either. I just used a stiffer spring. That worked. Holley power valves get perforated in other words they tear a hole in the diaphragm. This allows a huge amount of fuel to enter the intake in part throttle. The term blown power valve is descriptive.
Kane's problem can be summed up as a needle-seat-float that doesn't close when the desired fuel level is reached. Brass floats sometimes get hole in them so they sink. The nitrophyl floats can absorb fuel and partially sink. My first Holley rebuild, was an 1850 that came stock on my '58 Merc Park Lane with a 430. The little E clip on the float pivot fell off then the float fell off. The 10' flame from the carb was a little scary. That was my screw up. But the point is, any of these things can cause Kane's problem. I would just pull the primary float bowl and see what's going on.
