1973 Bronco questions on carb, engine
Gusorion81
hey Bronco family!!!! I've got issues with my 73' Bronco Ranger that im curious about and I hope you Bronco junkies can help me out. Thank you ahead of time
my first big trip I drove (highway) to a California beach in the morning and it ran perfectly fine. than when I drove back I drove the truck on the highway with the carb a lil less than half way open (totally forgot it was open), through the 25 min of driving on the highway (60-70mph) I got off the free way and it eventually over heated. now the question is
1) did having the carb less than half way open cause the engine to over heat?
2) if so what kind of damaged may I have caused? (the front tranny housing started to leak a lil & after refilling the radiator and a couple drives later the oil pan started to leak)
3)the truck runs great but temp starts to pass 210º on idle ever since the incident, did I create a bigger issue with over heating? should I replace the thermostat? water pump?
specs
1973 Ford Bronco Ranger
302 V8 2barrel carb
C4 Trans/3 on the tree
The good news is that 210 is not in the danger zone by a long shot.
But what do you mean exactly by the "carb half open" for starters?
G
Gusorion81
hey Paul, I heard 210 isn't bad but I would love it around 190º (im trying to see how to accomplish that) so I have a manual choke where you can open the choke to allow more air in, so when i took off I opened up the carb just a bit so I can get the engine on normal driving temp.
So you had the choke part way closed? If it was horrible you would have felt it running rough and lacking power. If it was open up enough to run ok, it was open up enough to not hurt anything.
Many of us have at one time or another left the manual chokes not fully open. Nothing in that that I can see that would mess things up on the short term.
Now, having the engine run rich like that (too much fuel, not enough air) will tend to foul the spark plugs and wash down the cylinder walls of oil and create excess wear. But not usually for one 25 minute session.
Still, would not hurt to pull the plugs and look at them. If they're dirty/black/sooty but new, you can clean them and re-install them. If they're older anyway, might as well just put new ones in.
The excess fuel leaving some unburned in the combustion process could indeed have raised the engine temp a little, but it would not leave a lasting issue I would not think. Not in my experience anyway.
But if there's anything I've learned over the years, one experience does not an expert make. So maybe someone else has other ideas.
But I would at least check the plugs, then check for vacuum leaks at idle, and check your ignition timing just for the heck of it.
73surf
USA
Welcome Gus,
I dont believe it would , running the choke half open / closed would make the engine run rough / sluggish , , others will correct my thought process
So tranny fluid was leaking or antifreeze? If its water / antifreeze then its a leak at the intake level on the backside of the engine or possibly the heater hose valve , , identify the fluid that is leaking and we'll prepare a better response
You will need to identify the fluid leak above first to make sure the over heating issue isnt related, , you could replace the thermostat with a 190* thermostat and see if that doesnt correct the overheating issue, , the current thermostat maybe marginal or sticking
G
Gusorion81
Yeah it was say half way open, and making the the block run rich was probably the issue as well. But you bring up timing, at times I can feel and hear the ignition struggles to fire up, I’m assuming that’s some ignition miss fire which is causing timing issues that might cause over heating huh? Thanks again for your feedback!
G
Gusorion81
Welcome Gus,
It didn’t run sluggish, it ran pretty well, I feel like Dirt said it ran rich which caused the block to over heat.
On the Tranny front part of the housing where the block connects to the Tranny there’s fluid (couple of drops) that is present. Maybe the over heating cause the housing gasket to tear? Not sure. Ok I will check the thermostat if it gets stuck or not, that’s not a bad idea, thank you surf
jckkys
I'm a little curious. Since '73s were built with 2100s equipped with automatic chokes what kind; IE make/model carburetor is it? Another thought is that in summer weather I've never had a reason to close the choke plate. The over rich A/F mixture kills some of the power and makes a lot of black smoke from the exhaust. Both are quite noticeable right away. Over heating isn't something I've seen with a forgotten manual or stuck automatic choke. Idling for extended periods causes over heating in many EBs. The hot air that passed through the radiator tends to get pulled through the radiator again, when your not moving. Coolant and transmission fluid leaks are also likely unrelated.
G
Gusorion81
Hey! So all I know is it’s a 2B carb with a manual choke. I believe the 74 is the first year with the auto choke. Do you think putting in a special cooler coolant will help? No I know the coolant and transmission oil are unrelated lol i need to be a little better on how I type lol I sound misguiding
Actually, '73 was the first year they used an electrically enhanced version, but they'd been using "automatic" chokes well before that.
Pretty sure that manual chokes disappeared in about '69 or so, but not sure if there were ever multiple choices, or if it was strictly a year-by-year thing.
For example, the '71 and '72 models still had automatic chokes, but instead of having any electrical hookup, they went strictly from heat generated by the engine. One of the heater hoses was routed right next to the choke housing, and they had the hot air from the choke stove setup piped in from the exhaust manifold.
I can't remember whether "choke stove" was the proper term for the hot-air riser from the manifold to the choke, or the hot-air riser tube from the exhaust manifold into the air cleaner snorkel. Maybe both were a type of choke stove?
I don't think we can know yet. Because we don't know the actual problem, or if it will even continue.
Not that a cooler coolant (100% water is actually better than any anti-freeze, but not sure about those "water wetter" additives) is not a good thing. After all, anything to make it more efficient is a good thing. But it should be able to cool just fine the way it is.
Did you check the coolant level in the radiator and overflow tank just to be sure you're not low?
Another thing. How long have you had the Bronco, and do you know if it sat around for a long time before you started driving it?
If it sat for a very long time, it might just be getting ready to show you every place, and any type of fluid it can let leak out. It might also have been running cool at one point, then hot at another because of other issues from sitting. Such as stuck thermostats and probably many other things too.
Including sticky or inconsistent ignition timing.
jckkys
1969 was the last year for manual chokes in Broncos. We still don't know what make carb you have. Ford Autolite 2100, Motorcraft 2100/2150, and Holley 2300 all work and were often used as replacements. All of them have tiny orifices that can be blocked by tiny chunks of crud that makes the engine run poorly.
G
Gusorion81
So I decided to get the marti report and wow the knob that I thought was the manual choke is actually a manual throttle knob lmao who would have known! So since we know that, I actually had the throttle knob a little pulled and allowed more acceleration on 3rd gear. So I might have been red lining the motor. That worries me now.
G
Gusorion81
I will check the carb tomorrow, it might still be the original carb. Not sure. So do you recommend a Holley 2300?
That's not how it works.
It simply pulls down on the pedal and would tend to not let it idle down. But it does not push it farther than your foot does, and does not "add" rpm to what you're normally driving.
Engine speed is physically dictated by the overall gearing and the only thing that can change that is slippage in either a clutch, or an automatic transmission.
So for example if you were driving 70mph and your engine speed is 3100 rpm with the hand throttle pushed in, it's still 3100 with the throttle knob pulled out slightly.
And if your engine was idling down to a normal speed, then the hand throttle was not having any effect at all.
Does it say "throttle" on the chrome bezel still? In '73 most of the bezels lost their printing because Ford added the "light bars" as indicators under the main controls near the center of the dash. But the knob on the left would theoretically have kept it's cast-in lettering.
Just as the bezel for the fuel tank gauge selector switch would have too, if you have dual tanks?
By the way, that's not how that works either.
A C4 is an automatic transmission, and even though it shifts on the column it is not, by definition, a "3 on the tree" because that nick-name goes to the manually shifted three-speed transmissions.
So you either have an auto with a column shift, or you have a manual with a column shift, or "three on the tree".
Yes, the auto is still "literally" a three on the tree, but the actual nickname only applies to manually shifted transmissions.
G
Gusorion81
Yeah it says throttle and I did notice the pedal goes down when I pull the knob. So since the knob was pulled less than half way do you think I just over worked the engine? Which caused it to over heat? Or maybe it ran rich and being at a stop light caused the radiator to boil the coolant so it over heated? Damn the mystery lol
G
Gusorion81
I just checked damn you’re right, C4 is only a automatic haha then wth do I have? I know it’s a 3 on the 3. Does the tranny have a specific name or is it just a “3 speed manual transmission”
In Ford nomenclature, it's a Ford 3.03 manual transmission.
Not sure what the numbers mean, but it might have something to do with the number of inches between shafts, or something like that. Or it's some other engineering number or version.
But they're all 3.03's from 1963 to 1986 or 87 I think. Maybe the "3" has to do with the year it was released.
There are different versions, RAT, RAN, HEF and at least one other, and variations on size and gear ratios, but the core design and function are the same between all of them.
The C4 was the only automatic ever offered in the Early Bronco, starting in '73. Though there were different versions on that too for other vehicles. At least two that I know of (pan-fill and case-fill) but there may have been others.
The big Broncos got the C6 auto starting in '78 and ran with it until the overdrive's took over the world.
Again, no it did not.
All it did was pull on the throttle pedal a little bit. If doing so caused it to idle a little high, or perhaps make it so you did not need to push the pedal with your foot as much, it did nothing to add load or stress to the engine.
At least nothing that have been able to think of. And you're certainly not the first to have ever driven it that way.
Lots of us have even tried using them as a poor-man's cruise-control. Never worked on mine because just driving a long the road vibrations would close it and push the knob part way back in.
Can't see how it could do this. You push on the throttle with your foot a lot more than the hand-throttle cable ever will.
Nope. Holding the throttle slightly farther open than normal does not cause it to run rich. If it did, they'd all run rich as soon as you push on the pedal.
Nothing changed dynamically unless it was just revving so high at the stop lights and that the weather was super hot that day and it caused more heat to be generated.
But the whole point of raising the rpm on the engine is to also raise the flow rate of the coolant to keep the harder working cylinders cool. The temperature is supposed to be stable once it's reached operating temperature. So something else is going on.
Have you driven it again since then? Is it still doing this? Have you checked that the choke is not closed, causing it to run rich? I'm assuming you pushed the hand throttle back in, so that's not doing anything. Have you been able to check your ignition timing? Are you still running points ignition, or has it been changed to electronic?
Still way too many questions before changing things that are unknown.
Boy that's for sure! It's a strange one, but it's not unusual for these things to act up. Maybe it's just so happy to be driven again and was so excited to see the beach again, that it overheated in it's excitement and is now much calmer.
Hey, stranger things have happened!
G
Gusorion81
Awesome thanks for the great feed back. I’m gonna burp my cooling system, make sure there isn’t any bubbles in there. I noticed my coolant overflow reservoir container is a little low so I’m going to top that off and check my ignition timing. And after I’ll look into a better radiator and fan. I enjoy driving it, it’s a time capsule for sure. Thanks again Paul!
