Jimboss77
I have worked through several issues recently and hopefully at my last. My engine will fire up immediately with a peddle pump and a quick rotation of the starter. Seems to be running smooth at first but as it warms up starts to ‘lope’ like a cam while at idle. Almost sounds like it will die but picks back up and continues to run. When I put it in gear (AT) it really bogs down and stutters.
77 stock 302. All emission crap removed and things blocked off. I tried adding pics......may or may not work. Distributer has vacuum advance connected to passenger side of carb. There is a port on the front of carb, driver side that is capped. PCV valve connected to rear of carb. T-fitting on rear of manifold has hose to brake booster, hose to tranny, and 3 other ports blocked off. I will start tomorrow with the simple check for cracks or leaks in vacuum system. Just want to know connections are correct. I have heard a high pitched squeal a few times that I first suspected to be PS pump. Removed the PS belt and still had the squeal primarily at rough idle, acceleration made it stop.
The carb......the fuel mixture screw on the driver side of the carb appears to have leaked fuel, wet and dark colored vs the passenger side which is clean. Also found evidence of possible leak around base gasket and did torque those 4 nut/studs and little more ~ 1/8 turn not much. I have done no carb adjustments. Just because of the leaks I’m thinking a carb kit is a good idea.
Timing.......in another thread I posted I believe the engine is from a 70’s mustang and I can’t see the damn pointer from above. Engine doesn’t ping, starts on first key turn, and runs 174-194 temp with laser temp gun on top rad hose. Feel good timing not an issue although it could be tweaked I’m sure.
Big thread I know but sometimes TMI is good.
