A very big thanks to Chuck at BC Broncos for sponsoring this ClassicBroncos giveaway!
Prize: Heim Steering System - This steering system includes 3 tapered studs, 4 FK heim rod ends, 1 tierod with the saddle welded on, 1 drag link and all the needed hardware. If you do not have the f-150 knuckles you will need to ream the knuckles with a tapered ream that can be purchased for as little as $25.
Description: (From the BC Broncos site) Now that we have a good way to attach a heim joint to the steering knuckle and pitman arm (the heim stud) we are offering a heim joint based steering linkage. We are using FK 3/4" chromoly heim joints with nylon liners for strength and long life, threaded 1 1/8" X .219" wall DOM tubing for strength and durablity and our heim studs for a solid anchor point. The saddle is welded to the tie rod for mounting the drag link or can be purchased separately. The saddle can also be used to mount the ram for ram assist. Please have the following measurements for your order: 1)(tierod) measure from the passenger side kunckle tierod grease zurk to the drivers side knuckle tierod grease zurk 2)(drag link) measure from the passenger side knuckle tierod grease zurk to the pitman arm grease zurk. Also, we need to know if you have a 2WD or a 4WD power steering box.
BC Broncos is also running a sale on these for the month of August. Sale price is $275. See their post in the Vendor Forum for more details. http://classicbroncos.com/forums/showthread.php?t=105181
The Rules:
Who can enter? - This giveaway will open to forum Contributors only as a way of saying thanks for helping support the site.
How do you enter? - Please post in this thread if you want to be in the drawing. That way only those that actually need the parts will be picked.
Deadline? - The winner will be drawn randomly on Tuesday August 14th (all entries in by 6:00 PM)
Good luck!
The Rules:
Good luck!
