CB Tech Help
eds66bronco
Essex, Vermont
update: got the cb installed over the weekend and antenna mounted to spare tire carrier(Wilson). checked signal with an swr meter and got 1 and 40 to come in at 1.75 and 20 at 1.5. scanning through some of the channels, i was able to pick up some chatter. all seemed well until i started up the engine and got a blast of radio noise from all channels. i checked all my connections and there were no opens or shorts. disconnected the alternator to see if it was the source of the noise and had no change. i suspect i'm gettingnoise from the plug wires or efi. i picked up power for the radio off the ingition switch (key on power) so i wouldn't forget to turn it off and kill the batery. i can eliminate the noise by playing with the squelch but that also eliminates the conversations i was picking up as well. maybe this is normal...Any advise... this radio stuff is all new to me.
Skiddy
You will have to get your power source from another location like a fuse that is on when the ignition switch is on, not sure which ones though.
eds66bronco
eds66bronco
Essex, Vermont
how would that be any different than grabbing the power at the ignition switch? the wire to the cb has an inline fuse in it (2 amp i think). i could try direct from the battery to eliminate noise from the switch.
Skiddy
yes you could try that and see what happens, if nothing changes you'll have to get a noise filter as 73stallion said. Pretty sure radio shack has them
Good luck
racebronco
Jeffersonville, IN
mine was doing the same thing, got a filter from summit & I have not had any problems since.. get a filter. I think they called it a rfi filter.
eds66bronco
eds66bronco
Essex, Vermont
Good luck
does the filter go on the coax or the power supply? try not to snicker at all my stupid questions....
Baja71
You need to run your power & ground directly to the battery terminals to eliminate noise. No two way radio should be connected any other way.
eds66bronco
eds66bronco
Essex, Vermont
check this out
http://www.stu-offroad.com/cb/cb_install-4.htm
i know it's a J##P site but very interesting stuff. the hum pitch does change with engine rpm and i suspect that running two electric fuel pumps is adding to the noise. i also noticed that with the engine off, there is a steady crack noise like the tick of a clock. not sure where that is from.. i don't have a clock in the truck. i also thought it was interesting that he was able to reduce the rf noise by grounding the exhaust. maybe the O2 sensors.. this kind of vodoo can suck up lots of time
eds66bronco
eds66bronco
Essex, Vermont
ok, this is going to put me over the edge
i isolated the noise to my low pressuere fuel pump (at least i thought) by disconnecting the coax at the radio. this killed the noise so i know my power is clean. i disconnect the low pressure pump with the antenna connected an voila! noise gone! did a bit of research and found a tech article on ford fuel pump noise supression. see link below.
http://97vette.com/sporttrac/rfi_fix/rfi_fix.html
bought all the RF chokes above and made a similar setup minus the toroids. test fit it by wire nutting the connections to see if it worked prior to soldering it in place and only a slight improvement. i then added a 0.1 micro-farad capacitor across the pump leads and it worked great. finally fixed it (or so i thought). take it all out solder/heat shrink all the connections, add in the 0.1 micro-farad capacitor, reinstall and now i'm back where i started... noise.
hmmm.. so i disconnect the ground to the pump and now the noise is still there... GRRRR... almost throw tools but collect myself.... chant mantra-this is a fun hobby, this is a FUN hobby....
disconnect everything and put it back like it was and still have noise with the low pressure pump disconnected.
Gummi Bear
Upgrade your grounds.
From the battery to the block, from the block to the frame, and from the body to the block.
Installing a ground bar, and bonding everything together there will help a lot.
You're getting 'dirty' power, the whole frame is basically like a harmonic antenna.
Filters help, but do not solve the issue.
eds66bronco
eds66bronco
Essex, Vermont
i added a grounding strap from the body to the block and one from the block to the frame in addition to the stock battery ground to the block. i also grounded the exhaust to the frame. nothing seemed to make any difference. where do you recommend locating the bar? i assume you would wire it direct to the neg on the battery. also did a direct to battery connection for power with no difference.
thanks for the info
Gummi Bear
If you can lay your hands on it, look for some 1/0 wire for the grounding, and make sure that your connections are clean, tight and out of harms way (rocks, heat, etc). It's also a good idea to smear some dielectric grease on the terminals and the bolts.
Painted surfaces make poor grounds, you need to remove this and get down to bare metal.
Locate the bar where ever works best for you. The firewall above heater hose inlets is a decent spot to bring everything to. You can get ground bars in stainless or copper. I've got a copper bar.
Another thing to look for is electrical 'leaks'. Old, worn, cracked, distressed insulation can cause humming through voltage leaking to ground without your knowing it. Verify that your wires are in good condition, especially the grounds, and that your connectors are clean and tight.
eds66bronco
eds66bronco
Essex, Vermont
all my wiring for the pumps is new when i did the FI a few years back. all grounds are to bare metal and i always use dielectric grease on evey connection. i'm not sure how i went from an RF noise that was eliminated by disconnecting the pump to a dirty power supply to the radio when it was clean before.
Landshark
California
OK, when you first turn it on, your High pressure pump should energize, does it make a noise, then stop after you have energized the system? If so, most likely you will have to do the samething to the High pressure pump, as you did to the low pressure side.
eds66bronco
eds66bronco
Essex, Vermont
originally, only the low pressure pump was making the noise. with the lp pump disconnected, the hp pump would prime and then shut off with no noise.
also , when it was running, i could disconnect the power to the lp pump and the noise would stop. now i'm getting noise even with the lp pump disconnected. i just can't figure out why it changed.
