Centech flasher hookup
yak67
can anyone tell me how the wires are hooked up to the terminals, "someone";D cut the terminals off and didn't mark which ones go where
thanks
Well, tell "someone" to quit cutting before marking! Just kidding. Probably doesn't matter which side the wires hook to anyway.
It seems to me that the flasher units are simple in-and-out affairs, so it won't matter which side is power and which side is the switch. And I really don't think you can hurt one by hooking them up backwards anyway. If anything, they just won't cycle properly, but I doubt you'd hurt it by experimenting.
If in doubt, I'd just hook one wire to each side and see if they work. Then, if it does, just make them more permanent.
One of the others should know if this is a fact, but I'd think you could do a quick test to see if they function properly.
Then you can snap the ends back into the plastic plugs. Or not. Simply attaching the wires with push-on connectors would work, but it's not as safe unless you have something surrounding the connectors to insulate them. For the hazards, there's power to one of the wires at all times. For the blinkers there is power any time the key is on. So, to be safe and proper, they should be insulated.
Good luck.
yak67
yak67
my question is there are more wires than terminals on the switch, so I'm assuming that mutiple wires need to be crimped into one connector, so which wires need to be crimped together? or does it matter? If that makes sense, I think there are 8 wires, and only 4 prongs on the switch (that's off memory, I'm not looking at it right now).
Viperwolf1
electron whisperer
Is it the stock flasher switch or a centech switch?
Viperwolf1
electron whisperer
The 4 terminals on the switch are all shorted together with the switch ON so it doesn't matter which terminal you put the wires to. However there are two sets of wires that need to be paired together. The left front park/turn wire needs to be paired with the wire that goes back to the turn signal switch for that function. The same is true for the right front park/turn wire.
If you don't get the pairing correct the turn indicators on the dash will do some funky things like come on when the brakes are on or indicate left when turning right.
yak67
yak67
thank you much, that's what I was looking for
Sorry 'bout that yak. I was thinking about the flasher relay unit instead of the actual switch.
Glad you got the expert advice though.
