Centech Fuse Box Location Question
ObscureMachine
Seatbelt Orifice Officer
World Headquarters
I'm going to be re-wiring soon, and I've removed and closed over the driver's side vent, and won't have a parking brake in the original position. I would love to put the fuse box, and a relay box up under that part of the dash somewhere.
Is the centech harness flexible (customizable) enough to put the fuse box on the driver's side, and still be able to run wire down the passenger side in the engine compartment?
Thanks,
Jim
needsmoarturbo
I would say no, it's pretty much made to go on the glove box. As with any other project, anything is doable with time and or money, but that would defeat the purpose of getting a centech. If you are set on putting it there I would look into a generic kit from American auto wire like maybe a route 9 kit if you are going basic..
Sent from my Moto G (5) Plus using Tapatalk
Agreed. If you already have the Centech, don't want to try to sell it on or return it to where you bought it to try something else though, you could try to remove the tape and wire ties from the branch junction where the fuse panel wiring enters the main cross branch and see how far you can make it go.
But I'd have to say that it would likely not make it all the way over to where you want it. Likely it'd end up somewhere along the steering column instead.
But I've never tried it, so if you have one already, measure it out to see what can be done.
But as said, it'd be a shame to undo all that nice taped up harness to customize it. Been done many times, but most likely it's due to the Centech's lower price than it is to it being easier to customize.
You can still get a Bronco-specific harness of course, such as the recommended AAW or even the Painless. But if I was contemplating what you are, I'd go for one of the universals too, like was recommended, and even consider one of the Ron Francis harnesses.
They are designed to go just about anywhere (but are big so actually NEED to go over by the pedal location in most EB's) and even have versions that are held in place by a big magnet. That type is super easy to mess with now and later as you can pull the whole fuse panel down to where it's easier to work on.
Another nice feature of many Ron Francis harnesses is the fact that they're terminated at the "load end" instead of the fuse panel end. What that means is that you simply plug the harness into wherever the component is (say the headlights for instance) and then run the bundle of wires from that corner of the rig back to the fuse panel the cleanest or easiest way possible. Easy to terminate at the panel, but this method is likely why the RF fuse panels are larger than most. But they're a cool option.
The magnet thing would be a big benefit I'm thinking, if you use that area under the cowl.
If you want to be super trick and bitchin' wiring-wise, you could use one of these American Autowire HD harnesses: https://www.wildhorses4x4.com/produ...y-Universal-Harness-Kit/Bronco_Wiring_Harness that pretty much lets you do whatever you want.
Make sure you document what you're doing though, as lots of members would love to see how you lay yours out with the panel in that corner.
ryan97
Richmond
Agreed, having just installed a Centech last year, it is made to be installed in the glove compartment or very close by there.
SteveL
Huge chevy guy
Hawthorne ca
I installed the centech fuse box in the ashtray hole on both broncos? It fits perfect. I cut the back off the ashtray door, put a hinge on the bottom and used a couple magnets to hold it closed.
Yeah that's a popular spot too. How's it been working out for you Steve?
I think when I first started with Centech we thought (maybe it was an assumption?) that they were designed in such a way as to reach both original locations. But I'm pretty sure it would be quite a stretch for one to be mounted over on the firewall by the driver's foot.
Not really a good spot for a fuse panel like the Centech's anyway. Or any other for that matter. The glovebox being a much better place to begin with, and a new glovebox liner the only additional part needed for that. Or just cut your old one and that's free.
How do those magnets work out on your door?
SteveL
Huge chevy guy
Hawthorne ca
The magnets work great. I glues 2 little magnets to the dash up top and the door closes against em. Never had it pop open yet.
JAFO
Beaverdam
I installed the Centech harness around October 2015. I put the fuse panel in the standard factory glove box location. Did install a new OEM type glove box liner as well. Have not had to access it once, but really is not difficult to get at the fuses if I do need to do it.
As to whether flexible, as memory serves it was a fat stiff bunch of wires and I think would be hard to mount anywhere else easily.
73azbronco
JAFO you going to use a rollcage that has bars by the dash? If so does that larger later style dashpad fit?
needsmoarturbo
I actually have a Ron Francis harness I didn't install because it had way more circuits than I needed. I ended up with a centech, so if anybody is interested in the room Francis the collecting dust somewhere..... Until it sells or until I get another project that I can use it on
JAFO
Beaverdam
Mine is all done. No, did not do the full roll cage with bars down in front the dash. Just did the four point cage. This thing doesn't see any off road action and I wanted easiest access to the dash. I still need to add some supports from cage to windshield frame so the frame stays ridged with the top removed.
ObscureMachine
ObscureMachine
World Headquarters
My plan is custom dash with no glove box. So the glove box, speaker and ash tray locations are out. I was looking to try to hide it, but be able to get to it easily.
If you're going that custom, you could simply create a hinged panel that lays up under the dash near where it would normally have been in the side of the glovebox, then pivot it down when you need to access it.
Or there are also the tunnel cubbies like this: https://www.wildhorses4x4.com/category/s?keyword=cubby where you could put it in the side of the open one or any surface of the closed blank one.
