Centech fuse box upgrade?
Millar
Birmingham
Afternoon,
I decided not to tackle the wiring harness install since I would probably have more luck shooting a monkey out of my arse. Is it worthwhile to swap out the standard fuse box that came with the Centech Complete Rewire Kit to the larger one? I did purchase the ignition adaptor kit and also will be running heated front seats, intermittent wipers and stereo. Is there any other worthwhile related upgrade I should consider at this time? Any help and advice would be appreciated.
Thx,
Millar
Nightstick
Bronco guy
I haven't completed the modification of my fuse panels yet (just enjoying being able to drive it for a while) but I have added a second one. I took the ALT power wire off the centech panel and added a twelve slot fuse panel to power non-stock gauges and solenoids. When it's finished, I'll have three seperate panels inside a waterproof pelican type box. Maybe I'll get it done this year, but I'm in no hurry.
brian72
Early Bronco Student
where you going to mount it....might make a difference
Millar
Millar
Birmingham
I was hoping glove box, but I am just gathering info, so it's TBD.
Thx
TN1776
For larger fuses, source one from a late 90s Taurus - you get ~10 "maxi fuses" in a neat package that even has a Ford logo on it. Otherwise auxiliary panels work great for smaller fuses for accessories.
72_EB
66to77
You could run standalone fused lines for your seat heaters and stereo, but I'd be thinking about doing that Centech before you start adding the extra goodies. It is a great harness for the $. I wouldn't change the glass fuse panel out alone unless that was the only thing the wiring needed. Will your alternator be up for the added duties?
Doesn't seem that you are that far from Bronco Graveyard. Maybe there is someone nearby that could help with a harness install.
JohnJohn
Richmond
I am about to do the same thing and add another fuse box to my centech by using the unused alt wire because I am running the 3G with the RJM harness. There are some nice waterproof blade fuse boxes available on eBay.
Millar
Millar
Birmingham
Thanks guys.
I am running a 100 Amp Chevy alternator. It was new a year ago from the PO. I have a guy that will be doing the Centech work. He has installed several, several new harnesses before. I will touch base with him and discuss the options everyone laid out here and hash out a plan.
Yes, JBG is 30 minutes from my house, which is great for me. They have been very helpful with my questions, no matter how redundant I can be. They have some sweet rigs in tht place in their showroom. There is a 66 with the camper on he back that is so cool.
The Bronco Ranch is pretty close too and Tom fabbed some sweet front and rear bumpers for me and is a great resource as well. I am lucky to have that knowledge base so close to me.
Thanks again for the advice.
Millar
NY-Bronco
Resident Dipstick
Weehawken, NJ
Afternoon,
Thx,
Millar
I also added a bunch of accessories to my rig and needed a bigger panel. I use this one right now:
You can get that here:
http://www.centechwire.com/catalog/panels/pdp1b.shtml
If after that you need more you can get this:
Hope it helps.
