Centech Harness Gremlins
First problem:
The orange female spade at the wiper switch is applied to the wiper switch for power at 950 (Power In for Wiper) in accordance with Centech. Moved my radio and Dakota Digital to the pigtail off of the Accessory fuse. My windshield frame is grounded since it is on a fiberglass tub. Wash function works on the switch. When I try to use the wipers, the voltage drops to 7.4 volts (according to the Dakota Digital face) and cannot make the wipers move. I will need to move the radio and Dakota Digital to another key-on 12V source. Where can I find that source?
Second problem:
I found the column hazard switch to be causing the intermittent flash on the left front. That is resolved. However, when the flasher is activated, all turn signals and marker lights flash. This get worse with the turn signals. Left turn works perfect. Right turn makes all turn signals and markers blink. The left side lights are not as bright, but still on.
Third problem:
The air horns will blow if I ground the relay. When the one-wire column is hooked up, nothing to the horn on the yellow wire. Kinda stumped on this one as well.
This is disappointing, I want this to work and cannot seem to make it do so. Any help is appreciated.
v/r,
SevenT
First problem:
Second problem:
Third problem:
v/r,
SevenT
