Centech wiring gremlins
'66U14
Hey all,
So I've been working on getting a Centech harness installed in my '66. Engine wiring is complete, as is most of the cabin wiring. However, I've been having trouble with the taillight/turn signal wiring. Since it's a '66 it has no reverse lights or side markers. And as far as I can see, there is no ground wire on the original harness. That leaves 2 wires to be hooked up on this new centech. Which wire goes to which post? Am I doing something wrong? Advice needed...;D
Not sure exactly what you mean by "that leaves 2 wires to be hooked up" in this instance.
Are you still talking about the steering column?
And which "posts" are you talking about?
Sounds like you're gettin' there. Should be easy to track down the last few solutions.
Oh, and did you add your own grounds to the system? Like not only the big one to the engine block, but another smaller one from the battery to the body? And then another one from the engine block to the body?
Those are some things that help no matter what harness you're using.
'66U14
The 2 wires I'm talking about are the ones on the end of the new harness for the taillights. And the 2 wires coming off the back of the taillight socket. I hooked one side up and the brake light stayed on constantly, and nothing else worked. Got me scratchin' my head...
Haven't added any grounds that the harness didn't come with. My neg battery cable runs straight to the frame (I assume that's how it's supposed to be).
Only if you want to melt something. So yeah, that's a negative (pun intended) there ghostrider.;D
First the battery ground cable MUST go directly to the engine block. The closer it is to the starter motor, the better. The starter is the single largest load in a vehicle, other than a winch.
The frame does almost nothing electrical on a Bronco, but it's still a good place to have a "common" grounding point if you want.
A secondary grounding wire of at least 10ga should run to the body. Ford put it on the wheel well near the starter relay/solenoid. You can too.
A third ground wire/strap should be attached between the rear of the engine, usually a spare intake bolt on V8's, to the firewall. Ford never did this on EB's, but they should have, and did on most every other car manufactured from the mid-sixties. If not earlier.
Since your dash and instrument cluster are poorly connected to the body too, through rust, paint, looseness and just old age, a small jumper wire to ground/bond can be used here too.
Grounding this way to the dash, the windshield frame, the instrument cluster, and even things like the radiator core support to the inner fender/wheel well are all good practices with Early Broncos.
You pretty much can't have too many grounds. Especially if the engine will be running EFI, electronic ignitions, bigger alternators and aluminum radiators, or you just like quieter radios too.
Those are all up to you as neither Ford nor the harness companies have done it for you.
Lots of discussions about just this subject hereabouts. Some good reading on the whys and wherefores.
Seems to me that there was at least one ground wire with the Centech harness under the dash. Might have been pre-terminated with a ring terminal, or might not. But I thought they had one.
