centech horn fuse gremlin
bronco italiano
Trying to help a buddy with a '72 Bronco. He had the Centech installed about 15 years ago. He had a horn issue and the centech horn fuse was blown. He also has aftermarket steering wheel.
-I installed a Tom's Bronco steering wheel and a Stebel horn that has it's own relay.
Horn worked for about 6 months but again the centech fuse is blown. The stebel relay fuse is fine.
-I plugged in a 15a fuse to the centech and right when I applied the battery hot lead it blew out.
-I am not real familiar with the centech harness.
-Any help is greatly appreciated
BI
Not sure how it's wired either even after doing several. They leave you with multiple connection options for the hood, and use overly technical terms for the wired circuits (like naming it "horn coil" on the wire for instance) so you may be dealing with dueling power feeds or something.
Or a simple short-circuit.
Try disconnecting the horn first to see if the fuse blows. As you disconnect things and the fuse still blows you know the fault is still up-stream.
Because so much has changed it's a harder hunt. How is the new horn's wiring and relay handled? Is it integrated or just included it's own relay?
If separate, simply pull the new relay out of the equation. You don't need two after all.
Then again, if the non-relay part of the Centech harness was utilized originally, perhaps the new relay is a good thing.
The new wheel is suspect too. Is the wheel and adapter(?) designed for a single contact or dual? Certain adjustments to the wiring need to be made when using one or the other.
Got pics of the horn by the way?
Good luck.
ransil
with the aftermarket steering wheel you want to use the horn relay, ( single or dual contact) the horn button will have 2 wires ( dual contact) on side needs grounded to the column( column should also be grounded)
the centech harness usually comes wired for 2 ways to run the horn hot thru the column or relay controlled. you want relay controlled.
at the column connector ( yellow wire i think guessing here might be a good idea to remove this wire from the connector) is the horn hot, do not use this one, you want the relay control wire which when grounded triggers the relay and the horn works.
B
bronco italiano
Thanks gentlemen. I will look into it today and get back. I will also post some pics later today.
BI
B
bronco italiano
Thanks gentlemen.
I think I solved it.
And I bought that cool tool too!!
-I called Centech and just spoke to the guy for a little bit and what he said made sense (but more technical that I could understand) of what you guys said. So you guys really "dumbed it down" for me so I could comprehend).
-So what I did was remove the relay that came with the stebel horn since the Centech has it's own horn relay.
-Took the Tom's bronco steering wheel/hub off and checked the turn signal contacts for power. Yes the big YLW wire was obvious.
-Was able to confirm 12v at the turn signal horn posts and activate the horn.
-So I almost overlooked the next step. I decided to check the horn button for continuity. the hon button had a metal trim ring that the button "Clip" locked into. The "clip" and the horn spade had continuity. Didn't make sense as I am thinking the steering wheel may have 12v sent to it when the horn button is depressed. A piece of black electrical tape to the trim ring and no more continuity.
-So far so good.
BI
Cool beans. So far though? Did you get it back together and it's all working?
If so, congrats on the quick fix!
