CENTECH IGN fuse Short in Start position
flexmerc
I have a 1974 Bronco, the wiring harness has been updated to a Centech version. Looks like the standard Part #6136 w/ a Centech to Stock Ignition Switch adapter.
My problem: I keep blowing out the 15A Ign fuse. I conducted homemade light test kit recommended by Gilbert http://classicbroncos.com/electricalbasics.shtml
and it "Shorts" (the light gets really bright) as soon as I move the key from the OFF to ON position. The Short goes away if I START the engine (move the key to the start position) and when the engine is running back in the ON position.
If I keep the key in the ON position for too long without starting, it blows the fuse (black burn filament in the fuse relay) and the engine will start but wont stay running unless I replace the fuse.
Any ideas?
Thanks guys
flexmerc
flexmerc
I replaced the ign switch from autozone a month ago and switch it back to the original ign switch with the same results...
73azbronco
Start disconnecting anything one at a time that is hot when in run.
Disconnect battery to stop blowing fuses, use the light tester you have to check for grounding.
Obviously short to ground in run.
Try the dizzy first, disco it then try the switch in run. coil, AC system, radio, etc,
Do you have an multimeter/ohmmeter, might be easier with one of those.
flexmerc
flexmerc
I tried disconnecting the fuses while in run, I tried all of them nothing. Except when I pull the fuse that blows, the ign sys fuse
I do have a multimeter, I'll have to conduct that test with dizzy when I get home today
I'll keep you updated, would pictures help?
904Bronco
San Martin, CA
So that fuse powers a number of different things under the hood.
The lack of a schematic from Centech is not helpful...
If I remember that fuse provides power the voltage reg, distrib/coil, choke, anti diesel solenoid, and maybe other things.
You might want to test those things to see if they have power from that circuit and then if maybe they are wired correctly... could be cause for your short?
KBUCK1
I have that harness. I do know if the choke wire grounds out itll blow the alt/emm fuse. Ask and then your alternator will go. At least it caused my new 3g alternator to go.
flexmerc
flexmerc
I've gotten out work late the last two days, but I'll have a long weekend to work on the truck.
-Felix
PS
Why aren't there competent mechanics that we can trust and Pay to actually fix our vehicles? I work 70-80 hour weeks, I'd gladly pay a solid mechanic to work on my truck!
Rant Complete, more to follow :)
Maybe there are. Where are you located?
Could just be that you're geographically removed from any good ones, or it could be you just haven't (unfortunately) run across one yet.
There are quite a few here that work for beer and beans (& pizza, ribs, chicken, grits and whatever else you're grillin'!) on a nice day to get you out of a jam.
What type of ignition are you running? What, if anything, did you do with the extra Green wires under the hood?
And you're saying that as long as it's running you don't blow the fuse, but if you leave the key in RUN without the engine running it will blow? Interesting.
Leads me back to the what ignition question though.
Good luck
flexmerc
flexmerc
I'm located in Fayetteville, NC
I believe it's stock....
I'm not sure about the green wires
Yes it only shorts while engine is off and Key in the RUN position , but not when engine is running and key in the RUN position
That was the interesting part. Was thinking maybe you had some aftermarket ignition stuff that was simply using more than the fuse was rated for, especially when the engine is not running.
Because, speaking of which... You're not supposed to do that. Ever!
Ok, a modern computer controlled vehicle maybe, but on our old analog versions, you NEVER turn the key to RUN for more than a few seconds if it can be avoided.
The reason is that the ignition system can overheat and literally burn out control modules in electronic setups, or points and condensers and coils in the old setups.
So when doing any work that requires the key on, use ACC position if possible. If you must use RUN, either start the engine or disconnect the ignition.
This is why the only two circuits hot in RUN only, and off in ACC are the ignition and the voltage regulator. All other circuits are on in ACC and RUN both.
That doesn't mean you don't have an issue still. Just that you should not be in RUN for very long with the engine off.
I meant to ask too, what size fuse are you installing?
flexmerc
flexmerc
@ DirtDonk....15Amp Fuse
Update, today I drove my Bronco for about an hour and then the cable connector for the positive battery lead melted, yikes. I replaced the red cable and lead connector and she starts hard and putters off. (SMH, so many problems)
Attached is the diagram for the ign fuse and how the wires are attached, I think I am missing a ballast in between the coil + and weather connector (please see attached CENTECH diagram).
FYI the A wire from the weather connector goes to the fuse ign sys and the B cable that isn't supposed to be used goes to the Auto Trans four wires (not sure which one)
flexmerc
flexmerc
This is the image I was going off of the CENTECH online manual
Disconnect the Yellow wire from the coil and see if it still blows the fuse.
Not sure why you would have any other wire on the coil + that runs anything other than a tachometer anyway. Or could this be going to a tach?
Even if so, temporarily disconnect it just to see what happens.
(edit: I see now that it's the "I" wire from the starter relay. So nevermind...)
Again though, you realize you're not supposed to be leaving the key in RUN for more than just what time it to start the engine, correct? This can overheat the ignition and maybe that's what's blowing fuses.
If you don't blow fuses when the engine is running, there's really nothing wrong.
Now, if the fuse blows within 10 or 20 seconds, then ok, there is something wrong.
Also, temporarily disconnect the White wire from the "I" terminal of the starter relay/solenoid.
Let us know what happens.
Oops, sorry I guess I can't read sideways anymore!
I see the Yellow wire is actually the other end of the White wire at the starter relay. That's ok, but I would still disconnect it for testing.
We should at least discuss this. Do you know why it melted? Only a few reasons really, but was it old and pretty worn out looking, or fairly new?
And what do you mean by "starts hard and putters off" please?
If you are running a points type ignition, you ABSOLUTELY MUST USE A BALLAST RESISTOR. With electronic ignitions you have a choice based on what coil you utilize, but with points you don't. You have to use a resistor to lower voltage to the system.
Points ignitions were developed when cars ran 6v systems.
It's the neutral safety switch to keep the starter from cranking when it's not supposed to. So that's ok for it to be inline with the starter relay's "S" post.
Delbert
NOT in California
Sorry for jumping your thread flexmerc.
Question for Paul.......When you say leaving the key in "RUN" are you referring to the ON position or start position?
No prob Delbert. The "RUN" position would be the same as "ON" versus "ACC" where only the accessories run, but not the ignition. So you can listen to the radio without burning up your ignition.
The "START" position is usually just referred to as that. Don't know of any other variations off the top of my head. Except for maybe "CRANK" I suppose. But then again, you don't see them labeled that way that I know of.
