Centech install - Firewall Grommets
rflud
Modesto, CA
I have tried a half dozen different ways to get the grommets (the one for the driver and passenger side) to seat in the firewall but with little effort (one finger) you can push the grommet out of the hole. I would imagine normal vibration from driving will also cause it to fall out of the hole. Anybody have any tips or tricks from when they did their Centech install?<br>
brokenhorse
Bronco Builder
Wisconsin
Use a little silicone seal to help slide it in and they go in HARD if you drilled the right size hole,use a screwdriver a negative small purpose to work the gromet into the seating chanel of the gromet.HTH
R
rflud
Modesto, CA
The holes are the factory holes for passing wiring from the engine compartment to the dash so I would suspect that it's the right size. Also, the hole is not just a whole is has a lip on it that in my opinion is keeping the grommet from seating.
I thought about wedging it in there and then getting some black silicone to hole it in place. That should work, right?
LSUpete
I know exactly what you're talking about. My firewall holes had a little lip on them, so the Centech would NEVER have seated properly. So, I cut the Centech grammets off and used my orignal grommets.
jims66
Use 3M weatherstrip adhesive, it's meant to hold rubber to metal. Silicone will have a hard time bonding to rubber.
