....Measure the hole size for the harness leg that will go down the driver side of the front. Replicate that hole size and location for the passenger side and you should be good. The harness should be good for the factory size holes in the firewall.
Unfortunately this does not work for all EB's. Some (all?) '70 and older rigs use a smaller hole on the driver's side that needs to be opened up to work with the Centech grommet. I don't believe that is the case for '71 and later however.
But definitely measure it anyway, just to make sure. I had to cut the hole larger on a '69 and that "should" be the same as in '70. But you never know about these things!
And the Centech bushings/grommets are notorious for not fitting properly in those later holes. The instructions tell you what size hole to cut, but you should maybe wait for those that have had the problems and deal with them to chime in and tell you what they did.
Some actually cut off the Centech grommet and used a factory junkyard GM truck bushing instead. They are available new now I think as well.
But since you have the option of re-sizing while cutting a new hole, maybe do some pre-testing with some scrap metal panels to see if a smaller hole works better than the size Centech recommends.
Good luck. Glad you stopped in to ask before getting to this stage in the process. Too many issues have been had in the past to ignore. I got lucky and on the ones I did the grommets worked fine. But I do remember one of them being a little finicky and "almost" not working, so it will be good to see what others did to correct it before you cut your firewall.
