Centech wiring rear replacement harness ?
coupe66
Cedar Park Tx
Has anybody every ordered just the rear tail light and tank sending unit wiring harness from Centech ? I have a Centech harness I bought with a parts bronco but it was missing the rear section.
I don't want to have to buy another harness.
I guess I could just make the rear section but it would be nice to buy it made with the same connections.
You can buy just the stock rear section pretty easily. Not too expensive and certainly less than a whole new harness.
While it won't have the same Centech (GM) colors, it will have the correct stock colors and should connect right up if you cut off the stock end and replace it with a Weatherpack of the appropriate orientation.
Seems like it would be pretty straightforward if you don't have any custom additions. Might not include the backup light harness section, but I think that part is handled in a separate junction from Centech anyway, so you should be good.
Pretty sure Centech won't sell just the rear harness, but you never know until you try. You might give them a call tomorrow just to see if they've got one laying around they'd part with.
Good luck.
