Center Mount Wiper Motor
Explorer
Raphine, Virginia
Looking at the options for my 66 wipers. This pic is in one of the conversion threads, but no info. Did this exist or did someone fab it? I've got a want ad for it, but don't even know if it existed. My 66 frame has holes in it in the center like something mounted there. I've got a complete later model electric setup I can convert, but would rather do as pictured so maybe able to use a wiper motor cover.
66fora69er
Wipers is all that is keeping my 66 from being inspected and on the road. I dont want to drill any new holes in my window frame. Looking forward to what you find out. Subscribed
Ohio Bill
Riverside, OH
I installed the later OEM wiper system on mine with out drilling (fitting) system taken off of a 69'. fishing wire up thru the windshield mast was a trick but it works.
66fora69er
I have seen those but wasnt crazy about the motors not being synched. Tom's (i think) used to sell one that was synched but had a big box around it. I called to order it and it had been discontinued
1sicbronconut
Look at where the motor is and look at the rear view mirror, it's not in the center;D . I did the same conversion as stated in the links works great, do the Jeep wiper arm conversion at the same time if you can.
Explorer
Explorer
Raphine, Virginia
You're right. What I actually meant was getting the motor between the wipers making it easier to put a cover over them. Didn't notice how far it was off and looks like he used a drop bracket the way the motor is pointed. Screw it, I'll do the conversion or buy the dual motor kit. Got enough hassles already with this project.
zeeman1
Seattle
Unless that was covered I think the motor moving around right in front of my face would be annoying.
Hawkdoc
Huntsville
My roll cage is in the way of my cover and yes the back and forth makes you a little crazy!!
Hawkdoc
Crush
Greenbottom, WV
someone on here posted a conversion from an FJ-40. Small motor with cable drives. Supposed to be almost a direct bolt in but i cant find it anywhere. I hope they chime in here.
