Steelstacks
- Oct 22, 2018
- 32
So I took the bronco for a drive the other day and I wanted to see how fast it could go where I still felt safe and comfortable. Got it up to 60 mph and it felt good but I didn’t want to push it any further.
When I got home and about to pull in the driveway in 2nd gear. I have a 3 on the tree. It starts to make a sort of clicking sound when I press on the clutch and then when I let go of the clutch and slow down to a stop, it stalls. I start it up again and try to drive into the garage and it stall as again. At this point I realize that it is stuck in second gear. Press the clutch all the way down and I can’t get it out of 2nd gear.
So it starts in 2nd gear with the clutch pressed but I can’t change gears. When I try to drive it goes for a little then stalls. I look under the truck but I have no idea what I’m looking for as I don’t know much about transmissions. Then I see this
I press it and it moved forward. I get worried so I quickly move it back to where it was. Then I get back in the truck and try shifting and all of a sudden it shifts fine! So I have a few questions.
1. What is the thing in the picture that I pushed that switches back and forth?
2. Why was I stuck in 2nd gear and unable to shift to another gear? Do I need a new clutch or transmission?
3. Do I need to replace or add to my transmission fluid?
Also I wanted to change my transmission and transfer case fluid anyway. Can anyone tell me where to find the manual transmission fill and drain plug and also the Dana 20 fill and drain plug.
I know that is the Dana 20 but so is the transmission in front of the Dana 20 towards the engine? I couldn’t get back there to take a picture. Looking forward to some feedback! Thank you.
