Is it the Dana 20 or the transmission? has it always done this?
Without removing it, you can open up the side easily and look in there with a light...
Check any of the gears for missing or worn teeth
Check to see if there are bolts which are too long and rubbing
Or could be the T-Case handle - mine chatters in 2nd gear only under power
I guess the brass bushings wear out and the mounting bolt gets loose
There is a post on how to take it apart and replace the worn bushings
