I've seen this several times over the years. Put the bigger motor in, blow the fuse every now and then.
Answer is the opposite of what we've been taught over the years. Just put a bigger fuse in.
And no, I'm not kidding. If you have a 20a in there now, then install a 25a instead.
The extra 5amps is not enough to melt any wires in the system, and is usually enough to stop the blowing. If a fuse rated at an extra 5a blows though, then you do have to look for more issues. Such as too many accessories on that circuit, failing connections and splices, motor drawing too much current, fuse contacts corroded, etc.
Since you've been replacing fuses the fuse is not corroded, but what about the old contacts in the fuse panel? Are they pristine, or somewhat less than that? If less, then it's time to at the very least take a wire brush to them. If you can twist your neck around enough to see the backside of the panel, look for rust, dust and fur-balls building up. Clean it out the best you can and look for any signs of over-heated wiring like brown areas up near the terminations.
If this is a '70 or older you'd have other issues, but since it's a '76 the fuse panel is slightly more protected up in the glovebox. But it can still get rusty and dusty, so check it out.
In fact, check it all out before you up-rate the fuse just in case. But if all else is in great shape still, those extra few amps won't hurt anything. And you can even go up slightly if you can find fuses rated at different increments. I think they're all 5a increments at that level, but could be worth a look for a 22a or so.
Good luck.
