dISC BRAKES
sO I CAN'T TELL IF YOU ARE PUTTING DISC BRAKES ON THE FRONT OR BACK. wELL I AM GOING TO SHEED SOME LIGHT AN YOU MESS! wELL FIRST OF ALL YOU NEED TO KNOW WHAT YOUR WORKING WITH. iF YOU BRONCO IS NEWER THAN A 71. i HAS A DANA 44 ALMOST 99% SURE. sO IF IT DOES. aLL YOU NEED TO DO IS EITHER GO TO A WRECKING YARD AND FIND THE KNUCKLES THAT THE BALL JOINTS GO INTO. iF YOU CAN FIND A FORD TRUCK 4X4 FROM 73-79 F150 IT WILL HAVE THE ONE YOU NEED TO PUT DISC BRAKES ON YOUR. oK IF YOU ARE LOOKING AT THE AXLE RIGHT. tIRES PULLED OFF. yOU WILL SEE THE PUMPKIN OR GEAR HOUSING IN THE MIDDLE. aND AS YOU MOVE AWAY FROM IT BOTH WAYS YOU WILL COME TO THE END OF THE SOLID TUBE RIGHT. What you need to put disc brakes on your is everything thatis after th end of the tube. There are two ball joints u can see that are what hold the brakes and everything on to the axle tube. Yo need to remove the two ball joints on each side. So all thats there left is the bare housing at the end. And when you go to install it on your. All you have to do is knock the ball joints out of yours and put the whole assembly one in place of yours. Make sure yo buy new ball joints.
Oh and i just found this yesterday. Its everything you need to buy and know to install discbrakes on your rear end with small bearing housing for under 150.00
Dodge disc brake conversion for 9"
From BroncoWiki
Jump to: navigation, search
Contents [hide]
1 Description
2 Parts required
3 Details
4 Installation
[edit] Description
'The Dodge 1500 Conversion is a low buck disc brake conversion for the Ford 9"'
[edit] Parts required
Part Part No Price Source
Rotors from the front of a 1995 Dodge 1500 4x4 5365B 26.99 ea Autozone
Calipers/pads from the front of a 74 Blazer 24.99 ea including core Autozone
Flex brake lines to match the calipers - - Autozone
Banjo bolts to match the calipers - - Autozone
Caliper pins H5004 7.99 per side Autozone
Weld on Caliper brackets 91641008 9.99 ea Speedway Motors
Note - Part # 91641009 may also work for the caliper bracket. It depends on which caliper pins you use.
Your welcome
