chevy 71 blazer disc spindle
socalrick
Tionesta
Does anybody know if this'll work on the conversion? If not, what is the difference between the spindle from the 72?
Viperwolf1
electron whisperer
The key is that the blazer has to have a dana 44.
There is another thread going on now about using a spacer/washer on the bronco drum spindle instead of swapping spindles. You may want to look at it.
Boss351
Foxboro
there is 2 different spindles 1 is a big bearing and 1 is a small bearing The small bearing ones are used for around 3 year 73 74 and 75 those are the ones you need but you should check out the thread on ford drum spindle and chevy conversions
I am not a chevy guy, so I could be wrong. But I didn't think Chevy came out with disk brakes until '73 on the 4WD. Could the '71 Blazer you are looking at have had it's axle/brakes replaced with newer parts?
socalrick
socalrick
Tionesta
lmc has the disc spindles starting as early as 67...yeah I was kinda surprised to.
Does anybody know where the thread is for using a washer for a conversion?
feitctaj
FNG
Group W Bench
Wow , the small bearing spindles are cheap and easy to find almost everywhere. the thread on using the washer sure seemed like it was taking the long way around the barn;)
z-one311
Payson, Utah
dISC BRAKES
sO I CAN'T TELL IF YOU ARE PUTTING DISC BRAKES ON THE FRONT OR BACK. wELL I AM GOING TO SHEED SOME LIGHT AN YOU MESS! wELL FIRST OF ALL YOU NEED TO KNOW WHAT YOUR WORKING WITH. iF YOU BRONCO IS NEWER THAN A 71. i HAS A DANA 44 ALMOST 99% SURE. sO IF IT DOES. aLL YOU NEED TO DO IS EITHER GO TO A WRECKING YARD AND FIND THE KNUCKLES THAT THE BALL JOINTS GO INTO. iF YOU CAN FIND A FORD TRUCK 4X4 FROM 73-79 F150 IT WILL HAVE THE ONE YOU NEED TO PUT DISC BRAKES ON YOUR. oK IF YOU ARE LOOKING AT THE AXLE RIGHT. tIRES PULLED OFF. yOU WILL SEE THE PUMPKIN OR GEAR HOUSING IN THE MIDDLE. aND AS YOU MOVE AWAY FROM IT BOTH WAYS YOU WILL COME TO THE END OF THE SOLID TUBE RIGHT. What you need to put disc brakes on your is everything thatis after th end of the tube. There are two ball joints u can see that are what hold the brakes and everything on to the axle tube. Yo need to remove the two ball joints on each side. So all thats there left is the bare housing at the end. And when you go to install it on your. All you have to do is knock the ball joints out of yours and put the whole assembly one in place of yours. Make sure yo buy new ball joints.
Oh and i just found this yesterday. Its everything you need to buy and know to install discbrakes on your rear end with small bearing housing for under 150.00
Dodge disc brake conversion for 9"
From BroncoWiki
Jump to: navigation, search
Contents [hide]
1 Description
2 Parts required
3 Details
4 Installation
[edit] Description
'The Dodge 1500 Conversion is a low buck disc brake conversion for the Ford 9"'
[edit] Parts required
Part Part No Price Source
Rotors from the front of a 1995 Dodge 1500 4x4 5365B 26.99 ea Autozone
Calipers/pads from the front of a 74 Blazer 24.99 ea including core Autozone
Flex brake lines to match the calipers - - Autozone
Banjo bolts to match the calipers - - Autozone
Caliper pins H5004 7.99 per side Autozone
Weld on Caliper brackets 91641008 9.99 ea Speedway Motors
Note - Part # 91641009 may also work for the caliper bracket. It depends on which caliper pins you use.
Your welcome
